After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser C900 resumes to produce colourful output. Unfortunately, I do encounter the following printout problems: 1. Whenever I print some coloured shapes, an identical shadow in greyish blue colour corresponding to the coloured shapes appears at the bottom on the same paper output. 2. Whenever all four colours (black included) are used to print out different coloured shapes, red coloured flakes appear surrounding the edge on all coloured shapes being printed. 3. No red coloured flakes appear if only three colours are used to print out any shapes. E.g. if I print only one red and one yellow or blue circles, I do not have red coloured flakes on their edges. But if I print circles in red, yellow and blue colour, all with black edges, I will get red flakes surrounding all edges of the circles. I am frustrated and cannot figure out which component is faulty. Clearly I have two kinds of problems: the problem of greyish blue shadows on all output, and the problem of red coloured flakes on edges of shapes under certain circumstances. Can you offer advice what to do to rectify the problems?
Posted by KL on
Erna Leenaars
    New Friend:
  • 87 Answers
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Posted on Jul 08, 2011
Change ink color
first you have to drain the ink... to do this after making a master with a heavy image on it.
1. turn off the machine and start it up while holding left and right print position buttons. when machine starts up you will see a number ... press the c or stop or yellow clear to reset that to 0000.
2. place paper in the paper tray and enter 888 and press start.
3. the machine will start printing .. let it print jntil the image is very light and press stop.
4. press the c clear or stop button to reset display to 0000
5.place the new color you want into the drum and enter code 890 and perss start.
6. hold down the yellow reset button u til the machine restarts.
7. all done! but please note you will have color mixing and banding for a few thousnad copies until the old color gets purged, there is no way around this.
Jun 14, 2013 | Riso RZ390 Duplicator
I have an epson stylus SX600FW printer. i have used the compatible ink cartridges for months. just lately the black ink cartridge is not working when you want to print out and you have black and coloued...
The black catridge is depeleted. Some cartridges have a chip which is resetted after power up so you won't know how much ink is left.
On the other hand never mix orij. and compat. carts together.
pls. vote for better service... Thank you
Nov 13, 2010 | Office Equipment & Supplies
Canon JX 210 P Ink Level reset?
its not recommended to refill the cartridges as it causes problems!It recommend getting a geniune cart!
Apr 05, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
Have a Magicolor 2430 DL. Getting message "drum low". Does this mean I have to replace the imaging drum or something else?
Most all replaceable parts on MagiColor printers are literally scheduled to be replaced after a certain number of pages printed using them. Officially, this is to ensure print quality remains sufficient. Unofficially, it's just another way to **** money from your wallet.
That being said, there is likely a fuse somewhere on the OPC drum unit that, when replaced, will reset the page count for that unit. Once the page count is reset, the fuse is blown, and counting resumes.
Examine the unit for large, silver, metal contacts. The fuse will be underneath those (or very nearby). Either replace the fuse or temporarily short the contacts. If you short the contacts, turn the printer on, verify the printer "thinks" the drum unit has been replaced, turn back off, and remove the short circuit.
Jul 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Speratice printing
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer.
Good Luck
Mar 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Problem with printing page
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Replug in the Power Supply......
Try to Print it will work fine..........
Jan 05, 2009 | Lexmark X2500 All-In-One Printer
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Won't print black text
dear
it isalways header printing problem or some time ,checkcatridge assembly stacking or not if stacking replace,or catridge ink flow late,means in between catridge and printing head,conduct with paper. replace head assembly.
by.by
Jan 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
306 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
