Question about Motorola Mag One BPR40 Two Way Radio
I just want to know how to clone the motorola rdm2070d
Posted by nugnes on
eradiostore
  • Motorola Master
  • 1,658 Answers
You will need the RLN6303 RDX Radio to Radio Cloning Cable, or two drop-in chargers, or the multi-unit charge tray. Instructions for cloning are on page 51 of the user guide: http://www.weatherconnection.com/manuals/RDV5100.pdf Best regards.
Posted on Jul 09, 2011
How to program a Motorola rdm2070d to a baofeng bf888s
The RMD has a set frequency list. Those are factory programmed and cannot be changed. Your baofeng can be reprogrammed to most frequencies.
Critical! First, make certain both are in the same band: Uhf or Vhf.
Make the list of frequencies you need both radios to use. If the RDM has it in the list, you are good to go! If it does not, and you must match the Bao, get a new radio. There are no mods or hacks for an RDM.
Feb 25, 2017 | Motorola Radio Communications
Clone Motorola BPR40 with PMDN4060AR, but I'm getting a low continual tone from the slave radio from Ch 2 above
Even with a cloning cable, you cannot always clone. The source radio and receiving radio must (1) be the same exact model, (2) have cloning enabled in the software a dealer used when they were programmed the first time. It sounds like you are doing the correct procedure.
Nov 18, 2015 | Motorola Radio Communications
Cloning of mc65
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Nov 07, 2014 | Motorola MC55/MC65 1-SLOT ETHERNET MODEM...
What radios are compatable with motorola rdm2070d
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
Jul 20, 2014 | Motorola Radio Communications
I have a motorola rdm2070d radio and am trying to turn the keypad tone back on
Keypad Beeps
Keypad Beeps can be enabled/disabled by
short pressing SB2 button (until radio 'chirps')
while turning ON the radio.
Here is a link to the user guide: http://www.astracomm.com/media/pdf/RDX_Display.pdf
Best regards.
Dec 27, 2010 | Radio Communications
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
Program motorola rdm2070d need to program
The RDM2070D is non-programmable. It operated on pre-selected frequencies. (This radio belongs to a major corporation, and is not intended for use outside their company.)
Oct 12, 2009 | Radio Communications
Motorola GP2000
http://www.batlabs.com/gp2000.html
Cloning
These radios support cloning parameters between a master and slave radio.
Cloning only transfers the user's settings from the master radio to the slave. Things like tuning values, serial number, etc. are not changed.
To clone a master radio to a slave (target), perform the following:
    • Make sure both radios are off
    • Connect the cloning cable between the two radios through the programming port
    • Turn on the slave radio
    • Press and hold the "A" button on the master radio and turn it on
    • The master radio will display CLONE if cloning can proceed, otherwise an error will be displayed
    • The slave radio will display PROG while it is being programmed
    • When cloning is complete, the master radio will display END and the slave radio will reset automatically
    • Disconnect the radios from the cloning cable
Feb 15, 2008 | Motorola Multi Unit Charger with Cloning...
Motorola Mag One BPR40 Two Way Radio Logo
594 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
