SOURCE: Hoover Steam Vac LS F5897-900
hi i have the same steam vac when you want to use the tools but it in the upright lock grap your hose and your ready to 6473
SOURCE: I need a manuel for a hoover steam vac ultra
Hi
You need to find the model number and enter it into the location bar after you follow this link which wil take you to Hoover's main U.S Site.
http://www.hoover.com/CustomerService/Manuals/Default.aspx
SOURCE: how do i change the
Are you sure there is a belt in there? Here is a schematic.
http://www.vacshopusa.com/pdf/hf5837900.pdf
Any good vacuum repair or sales shop that does Hoover should be able to order you any part
SOURCE: Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
SOURCE: I have a hoover steam vac ultra and have no
Go on the internet and look up the instructions for it then print it out and keep it!!
