Question about Avaya 4602SW IP Phone
4602sw sits at the discover screen with the IP address of the medpro in the display. Anyone know what the problem may be? 4610 on the same network works fine.
Posted by Lisa Logan on
2 Related Answers
Anonymous
SOURCE: How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Posted on Feb 15, 2009
Anonymous
  • 10 Answers
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
How to see start con Avaia 4610?
Press the options button (the one with the checkmark)
This phone will not display a startup screen. It displays the binary files that it is using to boot the phone.
May 31, 2010 | Avaya 4610
How do I add a new user to scanfront220p
Best advice is to access the web menu on the device and log in as the administrator.
Firstly, the network scanner needs an IP Address in order to access the web menu. You will need to log in as an administrator to change the IP address settings on the device.
I found that the default "administrator mode" password was just blank - no password whatsoever.
Sit down at the scanner and click the administrative mode or administrator button at the login screen. You should be prompted for the password.
If you have a router that uses DHCP then be certain that the device is configured for use with DHCP. Otherwise, configure a static IP address on it that is within the IP range of the network it is connected to.
Once you have either discovered the IP address of the scanner or assigned one manually you will want to go to another computer on the same network.
To access the web menu you will need to go to the IP address of the device - I.E. if the scanner has an ip address of 192.168.0.2 type in:
192.168.0.2
into a web browser (as though you were typing in http://www.google.com - ONLY type in the numbers and periods). The web browser needs to be on a computer that is on the same network or connected directly to the scanner via an ethernet cable and have an IP address set statically on its network card. I would google "Setting a static IP Address" and the name of your OS.
From there you will see a "To Administrator Mode" link in the upper right hand corner of the Web Menu screen. Click on that and authenticate with the same administrator password that was used earlier.
You should be able manage user accounts from within the administrative web menu!
Feb 11, 2010 | Canon ScanFront 220P Flatbed Scanner
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Ricoh FAX5000L - Check: Network Error! [10-40]
Usually this means it was previous;y hooked up to a network, or the network settings have changed and they are mismatched. Do you use it as a printer? If not, in the user settings, (I'm not exactly sure where, but you can download a manual at ricoh.com) just set all the network settings to 0's - for example Ip address, gateway, etc. Otherwise set them correctly in order to print.
Feb 03, 2009 | Ricoh FAX5000L Plain Paper Laser
Avaya 4610 sw
Are you using any application on your desktop to login or manually from the phone if you are log in through the desktop remove the application and intall it back this should resolve the issue
Sep 11, 2008 | Avaya 4610
Unobtainable Disc when dialing a number
The phone is not registered with the IP Office. Double check the IP settings of the phone. Callsv is the IPO IP address
Fileserv is the fileserver, usually the vmail pro server.
Sep 01, 2008 | Avaya 4610
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
Avaya 4602SW IP Phone Logo
398 people viewed this question
Top Avaya Computers & Internet Experts
Vincent G
Vincent G
k24674
ray gallant
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
