Question about Konica Minolta PagePro 1350W Laser Printer
I lost my cd and removed the program so I could install a new driver that i download but cant get it to download and i never see the 'run' button
Posted by citywoods on
Where can I find and learn how to replace my CD driver in my 2004 Dell pc?
Go on line to the Dell website and look for downloads related to the make and model of your CD. It also may be better to find the downloads at the manufacturer website of your CD player!
Jan 10, 2013 | Computers & Internet
Lacks wifi driver
You can download the WiFi and device drivers for your laptop from thelaptop manufacturer's WEB site.
I cannot give you the link to the laptop manufacturer's WEB site because youhave not provided me with the details of the make and model of your laptop.
Jun 29, 2011 | Computers & Internet
Lost my original driver cd please send me the drivers on my mail id
Hello. Download the driver for your SiPix StyleCam Blink by entering THIS link.
If you previously tried to install the driver CD of your digital camera, do a complete uninstall of it. Don't run DSC07.exe yet. (Start->Control Panel->Add or Remove Programs->Remove Sipix or Stylecam). After doing that, reboot your PC and start running the DSC07.exe file. Install it properly!
The driver above is available for Windows XP!
I hope I helped! If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 29, 2011 | SiPix StyleCam Blink Digital Camera
I have lost the installation CD for the Canon Powershot A460 so have no way of putting pictures on the computer.Is there some way i can download the software safely or buy a new disk? HELP.
you can download it form canon site or kodak easy share software. Download drivers, then install them, then reboot pc, then turn on camera, and finally hook up usb. Then run program or go to my computer and access camera files from there
Oct 29, 2009 | Canon PowerShot A530 Digital Camera
Were can I find install help for my X83 lexmark lost my CD
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
May 23, 2009 | Lexmark X83 All-In-One InkJet Printer
Cd lost
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Oct 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lost program
Yes. Go to the Brother website and look for support and/or downloads. You should be able to download the software and drivers that you need. That will fix your printer.Also, once you download the drivers/software, burn it to a CD so that you will have it for next time.
Aug 23, 2008 | Brother MFC3240 Multifunction InkJet...
Installing a printer
Click on this link. Pick your operating system & download your drivers. http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
To be honest if your driver software was running before you had the CD burner repaired you should not need to re-install Your printer. However if you think you need to re-install please uninstall previous software. Open control panel, open Add /Remove Programs. Find your Printer & un-install it. Re-start your Pc & hook up your printer & re-install the software.
We at FixYa try to help people. So if there was a problem with your CD burner why would any repair site need your whole computer including your printer? You don't need to answer that.
The average CD burner, brand new runs between $20.00 & 30.00 & I'm showing a DVD/RW burner that also burns CD's.
Feb 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I lost the cd needed for installation of my GE MiniCam Pro HO98756 Webcam!!
Did you follow explicitly the instructions on page 6 - 8 of the manual of not you will probably need to delete the driver remove the Cameras USB connection from the computer, reboot and perform the install step by step with the instructions.
Is your computer running Vista -- then use the new driver to install.
Manual
http://www.jascoproducts.com/support/download-files/98756.pdf
Drivers
not Vista
Vista
http://www.jascoproducts.com/support/download-files/98756_vista.pdf
Dec 18, 2007 | GE MiniCam Pro HO98756 Webcam
I lossmy webcamerra cd software
I lost my software to install my webcam....what can i do?
Dec 05, 2007 | GE EasyCam Webcam
Konica Minolta PagePro 1350W Laser Printer Logo
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
