SOURCE: not charging
Purchase a new battery, it should be high quality....don't think that high qualities is expansive, u shoul think the safety and I assure u it's worthy. If your battery is original then what u need is a new charger, a better charger for your phone. I've experience using a no original charger before and it doesn't perform well. But I think the problem is your battery and you need a new one.
SOURCE: sony ericsson k8ooi
i was charged my mobile k850i then one massage came my mobile seirious error,stop charging your mobile, stop using & plese contact sony ericsson call centre.
SOURCE: when i m charging.. it pops up a message saying
Hi xue,
This problem occurs due to fault in your charger, The some problem came for me once...
Note:Don't use a charger that was manufactured by anyone but Sony Ericsson
Enjoy ! Rate
Vinod Kumar Jayarajan
SOURCE: when I put W880i on charging, there is a message
try charging with the USB cable on a PC,if this works then it's got to be the charger that has a fault.if this doesn't then try cleaning the battery terminals or changing the battery if this doesn't work then you may have to take it to a mobile store to check the charging port.
SOURCE: i am using Nokia 6300
Hi! There some is a problem with the charger connection port, so you could always replace that. I had the same problem i got the phone charger port replaced, this saved me money on not getting any chargers.
Hope this helps Fazal Enterprise - www.fazalenterprise.co.uk
