Question about LG Cell Phones
My LG phone is needed to unlock the sim so i can use any sim were ever i go coz it says here on my phone invalid sim network lock when i inserted other sim.pls help me
Posted by maldita_cruz on
pechu_payal
    New Friend:
    Problem Solver:
  • 9 Answers
It locked to some network find that network,country it locked now,?then model of LG ....try code from here Unlock-Free.com/LG and unlock,then use any gsm network provider's SIM CARD.
Posted on Jul 13, 2011
What should I do to nokia 100. Coz whenever I switch on It tells me SIM not valid?
If your Nokia 100 phone displays invalid sim card message on the screen.It is locked to network.You need to unlock the Nokia 100 from current network lock to use with other network sim card.You can use any Pay as you go GSM sim card after unlock it.Get unlock code from the site Wickedunlock.com and unlock from service provider lock easily.
Aug 03, 2013 | Cell Phones
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
What can i do if the phone is saying invalidy sim card
If your Nokia X6 16 GB Displays invalid sim card while inserting other Network GSM sim card like MTN ?
It is locked to network.You need to specify which country and network it is locked now.I have bought an Nokia X6 16GB in INDIA but it was locked to Australia Vodafone network .I have unlocked it and now using it in USA AT&T network sim card.So you can unlock your Nokia X6 16GB from current network lock using the unlock code from the site Onlinegsmunlock.com after unlock it use with MTN network sim card or any GSM pay as you go sim card it will not display invalid sim card message.
Jun 11, 2013 | Nokia X6 16GB Cell Phone
What happens if you lg cu920 phone says invalid smart chip
If the LG VU CU920 Says Invalid Sim means it locked to network.You need to Unlock it...You can get the Unlock code from here Simpleunlocking.com/lg-vu-cu920/rs16wp9/ and Unlock it from network lock...Find the Network ,Country it locked now..Then unlock it.After Unlock it use with any GSM Network Sim card.
Feb 22, 2012 | LG Vu CU920 Cellular Phone
Invalid SIM card on Atrix
LG invalid sim solution
model GS 190
Dec 11, 2011 | Motorola Mobility ATRIX 4G (16 GB)...
Lg kp107b insert SIM problem solution
If your mobile says invalid Sim means it is locked to Network,You need to Unlock it,You can get the Unlock code from either your current provider or can get it from online provider..once i got unlock code from onlinegsmunlock and Unlocked my mobile..you can too try getting codes for your mobile and get it unlocked...
Aug 10, 2011 | Cell Phones
Invalid SIM
If your Phone says Invalid Sim while inserting the Sim Card means It locked to some Network,you need to Unlock the Phone from the Network Lock,To use any GSM network Sim card in the Phone,You need to find in which Country's Network it locked now? then what is Model,Brand ? specify those details and get The IMEI unlock code,i means Network Unlock code from here Mobileunlocksolutions and Unlock it,Using the Unlock instructions You can unlock the phone step by step also correctly without error....You can use any GSM Network Sim card in the Phone after Unlock it,You cannot use any CDMA network Sim card in the Phone after Unlock it...
Jun 27, 2011 | Computers & Internet
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
Invalid sim card
It shows Sim Error or else Invalid Sim...Or even though Sim Inserted it asks "Insert Sim"
If it says anyone of the error like that means Your Mobile is Locked To Network ..You need T Unlock it to insert other Network Sim GSM Sim Card....
It may locked to some Network....You can get the code here
http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock the Mobile from the Network Lock....
I hope..You got solution...
Jan 21, 2011 | Cell Phones
Cell Phones Logo
114 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
