Refrigerators Logo
Anonymous Posted on Jul 08, 2011
Filter replace light won't go out after you replace the filter
John Tripp
Level 3:
  • Maytag Master 4,656 Answers
  • Posted on Jul 08, 2011
John Tripp
Maytag Master
Level 3:
Answers
4656
Questions
Helped
1679027
Points
14883
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Rate if helpful, Sea Breeze
2helpful
2answers
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
2005 silverado cranks but won't start
I had the same problem . on my 2002 silverado it turned to be the fuel pump failed because the fuel filter was clogged. I did the work myself could saved myself 219.00 and labor if I replaced a 7.00 $ Filter .
We have an Jandy Ji8000. We have really enjoyed having it for years. Just lately, the filter goes on at the wrong time. If we try to turn it off at the panel in the house, it will not turn off. We have to...
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
3helpful
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Replace filter light won't go out
Try this:
Press and Hold The Light and Lock Buttons until the change filter light blinks. That is it.
Kelly
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
