Question about Toshiba Satellite A660-BT2G23 Customizable (PSAW3U0LY03C) PC Notebook
Hi, i can'to use function key and media buttons (eco,wireless,shortcut,play/pause,minus,plus) ...because i don't have any installation drivers for them ...my laptop is toshiba satellite A660 BT2G23 i just want the drivers . thanks
Posted by mody_yousef9 on
Manolito Mendoza
    Sergeant:
  • 236 Answers
You may download all versions of drivers for your Toshiba Satellite A660 BT2G23 available thru this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Posted on Jul 08, 2011
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
What do all the key functions do ?
Because you have a multimedia keyboard, there are additional functions for those special function keys. The icons on the keys will tell you if they do something special (like play sounds, increase the volume, etc) This kind of keyboard is designed for those who play DVDs and CDs and don't want to have to open a menu on the screen to quickly play music, etc.
Nov 13, 2011 | Belkin Multimedia (f8e820-blk-usb)...
I'm using compaq persario v3000..i lost functioning of my wireless connection button...it is in off mode.. are ther any shortcuts to on it??
if you look at the keyboard their is switch with which you can turn on the wireless.
it looks like a vertical line with fringws on the top a telephone tower type symbol
Aug 11, 2011 | Computers & Internet
As the Casio FX-991es Plus got a modular function if not this there away of performing mod on it.
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
May 03, 2011 | Casio FX-115ES Scientific Calculator
When using the number pad, hitting the forward slash key gives me popup of the VIA HD Audio Deck. Hitting the minus and plus keys lower and raise the volume of my speakers respectfully. How do I turn the...
This is happening because the forward slash has been assigned as a keyboard shortcut. To fix this problem - Open HD Deck->Info->Hot key and Untick 'Enable Hot Key Function..............
Sep 18, 2010 | Computers & Internet
How do i turn on the wireless card to my acer aspire 6930-6760
The media control buttons give access to volume control, skip, pause/play, and stop. The buttons are capacitive, and glow blue when the laptop is on. To the right of the media control buttons are four buttons that perform programmable actions. By default, they function as wireless on/off, launch Internet, launch Bluetooth manager, and launch Acer Arcade. Also, in the top right corner is a button which turns virtual surround sound on or off.
Sep 03, 2010 | Computers & Internet
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
I cant figure out how to delete songs off my mp3.
1. Go to the MSC menu
2. Press MENU button
3. When you see a song displayed in the LCD, press the Play key to pause the song
4. Once song is paused, press the MENU button
5. Select “Delete All” (all) or “Delete File” (one-by-one)
6. Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
Jan 14, 2009 | Nextar MA933A MP3 Player
Operating
pretty simple.
BUTTONS:
>|| : Play/pause. press to play/pause. press and hold to power on
+ : Plus. press to go to next song, press and hold to increase volume
- : Minus. press to go to prev song. press and hold to decrese volume
LOCK switch: locks buttons, prevents loading/erasing songs
SHUFF/NORMAL switch: switches between normal and random playback
that's about it
Jul 23, 2008 | Coby MP-C582 MP3 Player
GE HO98058 Keyboard Special Function Hot Keys
I'm not familiar with JetAudio, however in most media players you can choose for that to be the default player. I would make sure it is your default player first and then try to use it with the keyboard. The instruction manual only mentions compatibility with Windows Media Player though so it just may not work.
Dec 25, 2006 | GE HO98058 (ho-98058) Keyboard
Toshiba Satellite A660-BT2G23 Customizable (PSAW3U0LY03C) PC Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
