Question about HP DeskJet 920c InkJet Printer
I need to see photo of where the ink cartridges go for an hp deskjet 920c
Posted by joy_lh on
5 Related Answers
Anonymous
SOURCE: hp printer deskjet 920c
My HP deskjet 920c won,t stop blinking, eventhough I have changed the
color and black and white carthridge. It will not print.
Posted on Feb 18, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
Joe Fine
  • 628 Answers
SOURCE: I've just installed my HP
You can't operate the printer without the color cartridge, even if you don't need it. You can always keep an empty one in, but you must have both in.
Posted on Feb 27, 2009
Anonymous
SOURCE: printer won't print
wont work
Posted on Sep 22, 2009
meanlean28
Colleen Woodcock
  • 10 Answers
SOURCE: HP deskjet 920C replaced both ink cartridges and now it prints in
How do you clean the ink reservoir?
Posted on Jan 22, 2010
Does the hp deskjet 920c inkjet printer need to have ink in both cartridges in order to work?
yes hp was very clever in this if one cartridge is empty then it will not print as they run in path. i think its so you have to replace them more often so hp gets more money but whats new.
good luck
merry christmas
please take the time to rank this advice
Light flashes cartridge change, and change the cartridge and still flashing hp deskjet 920c
Make sure Orange protective cap (tape) has been removed from the bottom of the ink cartridge.
Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press PUSH mark until ink cartridge click into the place.
Hope this will solve your problem.
Thanks for using Fixya.
1helpful
3answers
I have an 920c that ran out of ink. (The top light said so). I bought a new black and a new colour cartridge and the light says its still out of ink. what do i do ? PS: I did a restart on it
Sounds like you forgot to remove your protective tape covering the ink cartridge heads and electric contacts.
Look there first, then re-insert.
5helpful
2answers
When we see high page volume in these printers, the cleaning ink resorvor needs to be cleaned. It may be even to teh point of stopping the head cleaning carriage from functioning.
It sounds like it is not priming and wiping the head of the cartridges correctly.
You can also try setting the head of the cartridge on a damp warm (water wet) paper towel. If there is ink coming out onto the paper towel you know it is the printer not the cartridge. If you are not seeing any color then I would change the cartridges again.
My printer could not print
Try installing the color cartridge. Some printers won't work if one of the cartridges is empty or defective.
Amber light!
Clean the contacts in the cartridge holder (Iso alcohol & cotton swab work well).
I've just installed my HP deskjet 920c printer, but the amber light seems to not stop blinking. I've installed only the black ink (c6615d) 'cause I have no use for the color ink.
2answers
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
The color ink in my hp deskjet 920c won't work
try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
HP DeskJet 920c InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
