SOURCE: Urgent help needed
Dear
ali
a ahmed
Please
go to:
http://www.panasonic.ca/english/customercare/sandd/softwareQuery.asp
And
put the laptop’s following details:
Model
Number: CF48 (not CF-48)
Keyword: ATI
Press
Search and you will find multiple drivers for your system.
NOTE:
Since you only state your laptop model as CF48 I assume that you have
the MK3 ATI Mobility Chipset. Check the label under your laptop to
check the full model number just to be sure!
Regards
Please
don’t forget to rate this solution if it was helpful, it keeps us
going!
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
I'm doing a clean install of XP but I can't do this as setup won't start bcoz the drive isn't bootable
SOURCE: no sound cf 48
download Astra software...run it on your computer.....you will get information of all devices through this software.....check the chip set manufacturer and the number for the chip set do a google search for that particular audio driver chip set you will be good to go
SOURCE: XP Booting off CD trouble
may be the file is damaged, if this is the only pc original cd, try to repaire it using the "disk repair polish" can be found in the markets.
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
