Depends on how old it is. It could have bad brushes in the motor or it may have burned up. Do you smell burned insulation etc.? If it just quit there may be a problem with the switch or the cord. Wiggle things and replug etc. to see if that is the problem. Otherwise, you may need a voltage tester to check for power.
SOURCE: The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
