I can't say for sure but this links may have the answer for you if you don't happen to have it with you it is a you tube video. good luck.
http://www.telephonesystemsdirect.com/phones/recording-the-day-greeting-on-an-idcs-28d
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
SOURCE: how do i change my voicemail greeting on my
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
