You will need a phillips screwdriver (preferably 2 different sizes - some of the screws are tiny), q-tips and a can of wd-40.
On the back of the brookstone (the darker gray side) you will find 4 screws inside of 4 channels. Take these out.
Put the fan on its head. pry off the 5 rubber bases and set aside carefully so as they won't lose their stickiness. You will see 5 screws beneath these. Remove them and then remove the bottom plate. Now remove the 2 screws and washers, noting that the rounded side of the washer was facing you. Now pivot the base so that the 4 holes on the outer part of the base line up with the 4 screwsheads that are screwed into the tower. Take these out.
The 2 gray tower pieces should now separate easily. set the fan on a newspaper and blow away as much of the surface dust as your can. Now use your wd-40 (with a straw nozzle attached) and spray into the motor area where the actual fan turns. Also spray, from the top down, along the metal rod that connects the fan to the motor.
Now use the q tips, dipped into warm water, to clean the dust from the fan "blades" and to clean any other nooks and crannies you can see.
Lube the motor up one more time, put the machine back together and leave to dry out overnight.
Will work like a charm afterwards.
SOURCE: Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
SOURCE: The fan has hair and
just had the exact same problem. there's 6 screws to remove along the back side of the fan grill, 4 of them are philip and 2 of them torx. don't know why they didn't just make them all the same! once the screws are out, you can take off the faceplate. you can then clean most of the fan, however it will be difficult to clean the area near the motor.
SOURCE: How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
