SOURCE: Printer Cartridge Carriage Stalls
the settings of the gears is misalligned.a technician at your place is advisable as this is a very important part of the printer if any of the arm breaks the printer may face major problems.still stick that arm with a cellow tape on it firmly and then give a print out.if the page prints properly that means it got adjusted automatically.
SOURCE: HP5650 Deskjet Carriage Stuck
hello dear; open the door let cartridge move to center, then UNPLUG the power, try to push the cartridge by hand left to right just investigate see where got stuck what cause this problem I believe you can make it. still have problem let me know.
SOURCE: my hp2600 printer says carriage jam and I have
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: We are receiving the error message Check Print
Upon power up, does the machine move the carriage assembly from one side to the other?
Generally, any message like that means the belt has a few teeth missing or is worn. The belt drives the carriage assembly to and fro. If the machine detects a slow down or stop, it will have you check the printhead path for obstructions. If there aren't any, then 9 times out of 10 it is a worn belt. Check for little pieces of black rubber under the belt and encoder strip.
I have also seen 2 other fixes: a dirty encoder strip (the plastic strip with little hash marks on it) and a faulty cutter. But most of the time it is the belt.
SOURCE: I received a new printer today, I installed the
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
