SanDisk 2GB microSD Memory Card Logo
Posted on Oct 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have purchased an micro Sd pqi 4 GB from my local supermarket and when I insert this car in my SD slot in my computer with VISTA home primium . my 3 Vista computers can not read the card as if the card does not exist. While when I purchased a SCANDISK similar SD card my computers with Vista can immediately recognise the card , Please tell me the reason.
Gerhardus Stroebel
Level 2:
Scholar:
New Friend:
  • Expert 101 Answers
  • Posted on Oct 01, 2017
Gerhardus Stroebel
Expert
Level 2:
Scholar:
New Friend:
Answers
101
Questions
0
Helped
20563
Points
161
I had the same problem. The chip is faulty and should be replaced by the store that you purchased the chip. This is no fault on your part and by the way the chip I had was also 4 GB
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Sep 21, 2008
SOURCE: Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Chris Fourie
  • 15 Answers
  • Posted on Dec 03, 2008
SOURCE: I have a simple question.
You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
Anonymous
  • 24 Answers
  • Posted on Jun 25, 2009
SOURCE: when i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
pk456
prateek chandra kala
  • 75 Answers
  • Posted on May 30, 2010
SOURCE: I have a Micro SD 2 gb memory card for donwloading...
actualy 2 types of memory card named micro sd and mini sd are available so what u have brought is not for micro sd
Anonymous
  • 57 Answers
  • Posted on Mar 29, 2011
SOURCE: when i insert my 4
Hello Sir !! Welcome to Fixya !! There are two possible reasons for this error.Either memory card is corrupted or your cell phone memory card slot is got damaged.
  1. IF your memory is got corrupted then you can troubleshoot your memory card by inserting in another phone.If it is not working then your your memory card is got expired.There is nothing you can do.
  2. If your memory card is working then your phone memory card slot is damaged.You can get it repaired by your nearest customer services center.
If this works for you.Then please rate or token of appreciation will be esteemed. Rizwan.
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
I have a PNY 2 GB micro sd card that some one gave me and it had music but i tried erasing da music on da computer but it said its write coppied and i formated da memory card in my phone n erased everythin...
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
3helpful
I need help with inserting my SD card into my laptop. The slot is way too big for it and when I tried putting it in, my laptop froze. I have a window vista and a sandisk 8gb memory stick pro duo card. My...
you need to either purchase a micro sd card adapter or a usb memory card reader, they are both pretty cheap and available in most supermarkets/electrical outlets but cheaper still on ebay/amazon/play etc it all depends how fast you need it.
How do you put your micro sd card in the computer?
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
1helpful
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      http://www.sdcard.org/consumers/formatter/eula/
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      http://www.cgsecurity.org/wiki/TestDisk_Download
      This is the best free software available for this type of problem.
How to expand my memory and what type of memory card to buy
It will certainly take a 2GB microSD card.
This link on Sandisk forums tells how to check if you have a version 2 that will take a 4GB.
forums.sandisk.com/t5/Sansa-e200-series/Sansa-e250-compatible-with-4-GB-Micro-SD-Card
Where to buy one? My local supermarket has them, or you could check a camera store, or even office supplies. as well as the usual computer or electronics stores.
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
