Cisco WVC210 Network Camera Logo
Posted on Jul 07, 2011
WVC210 CISCO PTZ camera... i can access through ethernet but can't access through wireless. I had tried installing in the sameway specified in the manual.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
278
Points
I had the same problem. Here was my successful solution:
reset the modem
only change the SSID (do not activate the security yet)
reset the camera
install the camera
set the static ip address
set the SSID to match the modem and save settings
unplug the power and the ethernet to the camera
plug in the power to the camera and wait for the lights on the front are illuminated
go back into the camera and set the security settings
go into the modem and set the security settings.
I hope this works.
tip
Cisco Wireless, Access to Information and Resources in Wireless Networks
Cisco wireless solutions ensure that your business is able to react to the constant demands of the fast moving global economy. And the Cisco Unified Wireless Network helps enable the Borderless Mobility Experience with a broad portfolio of products that provide anywhere, anytime access to information with the same quality of experience provided by a wired network.<br /><br />For every Cisco fans, they are familiar with all the <a href="http://www.router-switch.com/Price-cisco-wireless-ap_c5">Cisco wireless products</a>, such as <a href="http://www.router-switch.com/Price-cisco-wireless-ap_c5">Access Point</a>, Client Adapters and Client Software, Antennas, Wireless LAN Controller, Wireless Integrated Switches and Routers, Wireless LAN Management, Outdoor Wireless, Mobile Wireless, Service Control for Mobile Networks, Wireless IP Telephony, etc. <br /><br />Firstly, let's get some questions that were asked by people who used Cisco wireless products<br />"I need drivers, and help on how to set up a Cisco Wireless Adapter? I have a Cisco Aironet 802.11a/b/g Wireless CardBus Adapter that I am unsure on how to set up. I can't find drivers for it on the cisco website, or anywhere on the web. If anyone could link me to the drivers and tell me how to set it up that would be great!"<br /><br />"How do I enable the wireless in a Cisco Aironet access point? This is 1200 series Cisco systems AP which is shipped with the wireless disabled, I have only laptop at my disposal. I have tried to communicate with it using it's supplied ethernet cable but either my laptop does not see it or it does not respond. I have the small hand book that comes with it so I do know all the default settings."<br /><br />"Where can I get coupons for Linksys by Cisco Wireless-N Broadband Router? Where can I find a discount online for Linksys by Cisco Wireless-N Broadband Router?"<br />...<br /><br />No matter what Cisco wireless products you have, many people will be confused with how to use it. So we can learn some basic features of Cisco wireless items to help you know it well.<br /><br />Take Cisco Wireless Access Point as a typical example, Cisco Aironet access points and bridges connect wireless devices to networks, providing ubiquitous network access for indoor and outdoor environments. Cisco's next-generation wireless solutions offer comprehensive wireless coverage with up to nine times the throughput of 802.11a/b/g networks. Cisco enterprise wireless mesh helps enable cost-effective, scalable deployment of highly secure indoor and outdoor wireless LANs.<br /><br />Overview on some popular Cisco wireless Products<br />Cisco Aironet 1250 Series Wireless Access Points built on a robust modular platform designed for easy field upgrades, facilitating support of a variety of wireless capabilities<br />including data rates of 300Mbps per radio while providing reliable and predictable WLAN coverage.<br /> <br /><br />Cisco Aironet 1140 Series Draft N Access Points give six times the performance of 802.11a/g networks for reliable connections to Wi-Fi voice, streaming video, and business applications. Cisco Aironet 1140 Series indoor access points have a sleek design that blends into enterprise environments, and they can be powered with standard 802.3af Power over Ethernet.<br /> <br /><br /><a href="http://www.router-switch.com/Price-cisco-wireless-ap-1250-series-access-point_c55">Cisco Wireless LAN Controllers</a> (Standalone and Modules), simplify the deployment and operation of wireless networks, ensuring smooth performance, enhanced security, and maximum network availability. Cisco wireless LAN controllers communicate with Cisco Aironet access points over any Layer 2 or Layer 3 infrastructure and support 802.11a/b/g and the IEEE 802.11n draft 2.0 standard.<br /> <br /><br />Notes: More info such as price, purchasing info, feature details and specs of Cisco wireless products you can visit routerswitch.com---<span>Cisco Wireless</span>, or go to Cisco's official site see more wireless solutions and services. <br />
on Jul 19, 2011 • Computers & Internet
Both ethernet and power led flashing and never get steady for wap300n access point
Try another power adapter. Power should be constant and Ethernet when engaged will blink on and off.
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
We are currently installing wireless cctv and using alvarion access.We are encountering connection lost and sometimes got still pictures.What causes this problem? Thanks,
is it a PTZ camera or Fix? how many cameras? You need to look at the type of capacity (MBPS) & (PPS) , minimum latency and Jitter your camera manufacturre is recommending. Not all wireless devices offer low latency, Low Jitter, High MBPS and PPS needed for higher end cameras.
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
