This is almost
certainly a simple problem with your empty pump filter being clogged. The empty
cycle is timed and if it can't get all the water out in time because the filter
is blocked and slowing the empty down, then it will fail safe and won't step on
to the final spin cycle with excess water in the drum.
You need to
locate and clean the filter. Depending on the model (not familiar which with
the model you mention) there is probably a round filter cap on the front of the
machine at the bottom (It may be behind a small door or hidden behind a clip on
panel on the bottom) Many models of
this design also have a small hose to the right of the filter cap that you can
pull out, remove a plug from and drain off any water in the filter before you
remove the filter and get your floor wet, so take a look for this before you
remove the filter and get soaked.
Not sure about your question "Why would it fill up" Why wouldn't it fill up? Like walking through an entry barrier and then discovering the exit is locked, at the time you go in, you don't know you can
