Dirt Devil Featherlite Bagless Upright Vacuum Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The vacuum is hard to manuever; too much suction sound for less suction quality; I've cleaned the unit and replaced the filter. Is it the belt?
Anonymous
Level 2:
Sergeant:
  • Expert 422 Answers
  • Posted on Jul 07, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
422
Questions
0
Helped
104104
Points
985
Probably it is but vacuum motor and its associate mechanical parts should also be check and clean.
Clean the motor, if suction is still less, then the motor brushes is already wear and need to be replace.
Put back what you disassemble and bring it back together. You must be observant when doing that.
Thanks for asking.
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Suction in hose okay through floor piece not working
I'm sorry to hear you're having difficulties with your DC24. From what you've described, it sounds as if the suction relief valve is activating - this is likely to be due to a blockage in the machine, or because the filters need washing.
The easiest way to locate and remove any blockages is to follow the simple steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
DC24 has two filters, both of which need washing at least once a month, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
I'm confident that following these steps will resolve your issue. However, if you'd like any further assistance, call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
2answers
I've bought a dyson dc07 upright vacuum and need to know how to get suction through the hose as opposed to the main machine.
When the cleaner is standing in the upright position, it's engineered to divert suction automatically from the cleaner head to the hose. The correct way to use the hose, wand and dusting tools is shown in the user guide:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If there doesn't seem to be any suction coming through the hose when the cleaner is standing upright, you may need to check the machine for blockages. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-SY-HEPA_US
It's also a good idea to give the filter a wash, as demonstrated in the video below. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and always make sure the filter is totally dry before replacing it - this may take up to 24 hours.
By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
Kind regards,
Jack
No suction. upright position shuts off unit. Turning off brush bar shuts off unit. will only run in floor position but has no suction. no clogs found.
From what you've described, it sounds as though you may need to wash the filter. This video guide from the Support section of our website shows the correct way to do this:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Although you've found no blockages, it's definitely worth checking again to ensure nothing has been missed. This simple step-by-step walkthrough shows all the areas you should inspect:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
If you've followed these steps and are still experiencing difficulties, please get in touch with us free on 1866MYDYSON, or email [email protected]. One of our experts will run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
2answers
Plenty of suction from the hose pipe itself but no suction when vacuuming the carpet
Hello Can,
Go through this guide to help find the issue www.builtinvacuum.com/flowchrt.html. You should have suction without a filter. The bottom is on the unit, right? It needs to be air tight.
Apr 21, 2011 • Vacuums
The suction has decreased by about 50%. The brush
Check that there is nothing blocking the hose and that there are no obstructions around any of the filters, clean and replace filters too if possible. If you still find you have less than optimum suction , you may need to replace your motor. But it sounds like there may be a blockage or an air leakage somewhere in the unit.Good luck.
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
