This is a failure of the inlet valve if the water flows all the time but if the water flows uncontrolled only when the machine is put on start then it is the failure of the WATER LEVEL SENSOR which is normally a pressure switch.
When the level of water reaches the set level then the pressure of the water will switch on the switch to contact and so give message to the controller to SHUT down the inlet valve.
