Please describe more , you say when you press the volume button down then push power button to turn off screen, then you turn on again , and it doesnt work , what doesnt the phone or the function
try to start the download mode if it work volume down + lock button + Power
If it doesnt work you should sell it away as donor phone. my friend in samsung center told that they can't revive the phones of the download mode doesnt work...
Well try and resolder the controller one port I have had a problem with my and controller port for my sega and i resoldered the controller port and it worked again it could just be that then.
have your vacume lines checked out i dont know why but if they arent hooked up right it will cause the light to work but you cant set any speed to hold.
hold down the "Setup" button while pressing the "Options" button and the message will go away. Worked for me.
if tht doesnt help i recommend u to uninstall then reinstall the printer drivers .... if it still doesnt fix ur problem..... u wud need to clean the cartridge holders.....
good luck and have a nice day
either your motor or the regulator needs to be replaced which means taking the door panel off. I would replace the motor if it doesnt work on either driver or passenger controls and the regulator if it doesnt work on just the one side. I hope that helps you out.
