Question about Intel Computers & Internet
How to trouble shot the computer beeping - Intel Computers & Internet
Posted by aero_06 on
  • Archaeology
    Archaeology Jul 07, 2011
    your problem could be hardware or software - you'd need to post the mfr/model number of your
    hardware (the computer), and also your software (the Operating system & BIOS version) for help.
    And is the computer beeping instead of booting? or beeping after booting partially?
    of beeping while running?
    VERY IMPORTANT: how many beeps? Motherboards beep a given number of times
    when they have hardware errors.
    and what's on the monitor (if anything)?
Donna Joan Balitbit
  • 58 Answers
Posted on Jul 07, 2011
What does the beep sounds on GX670 mean?
When a computer starts up there is usually a POST signal or Beep that indicates all is well (One Beep).
That is standard on PC's and not always used on Portable Computers. More than one beep or successive beeps in a row can be alert of trouble with the CPU, Motherboard, RAM, etc.
May 13, 2014 | Dell Gx-520 Intel Pentium 4 2.8Ghz Desktop...
Computer has 2 beeps periodically
Sounds like your memory might be failing. Keep an eye and ear out for it.
Here is what your manual says about 2 beeps.
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/trouble.htm#wp1085300
May 31, 2012 | Dell Inspiron 530 Desktop Computer
It is not showing the post screen and beeping a long and continuous beep
a long beep is identicated your vga has trouble, but maybe it caused by ram error, first turn off your computer, open computer case, disconnect your ram and connect again, turn on computer, is the computer still beeping??if yes it mean the problem come from your vga card, do not use onboard VGA port, just insert PCI or AGP VGA card, your computer will work properly
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Foxconn (945G7MA-8KS2) Motherboard
When i press the power button i computer only has a shot beep an then a long beep and the computer dosnt start
I think that when an hp computer does this it's either the memory or processor that are not in order to boot the machine up.
Jun 29, 2010 | HP Pavilion s3020n (882780985063) PC...
If i reformat my computer, is the beep will not sound again? when i printing my computer begins to beep very long i thought it was the cpu overheating and i put some thermal paste... i turn on my...
Hello
No i doubt the beep will go away if you format.The beep or beeps are trouble codes,a warning something is not right.
Usually related to the cpu,memory sticks,or a video or sound card on the motherboard.or a issue with heat.
Check your motherboard manufacture websight for the codes.Usually a set of short beeps is memory.
Try taking the memory sticks out and reseting them back in.
Jun 16, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Rebooting problems fujitsu siemens
I WAS GIVEN Gateway model: FMN 400C I WANT TO MAKE IT WIRELESS ? IS THIS POSSIBLE ? HOW AND WHAT WOULD I NEED TO DO ? I HAVE BOUGHT AND INSTALL A NEW WIRELESS CARD..STILL HAVING TROUBLES WITH MAKING CONNECTION TO THE MODEM.I was on the phone with cable people.Yes I have wireless set up already.Where can i find instruction Manual? I can get green light on the card sometimes.Socket for cable either net wire be loose?
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
827 people viewed this question
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
