All the inputs they have relay switch i had 2 has gone on mine , or you have the relay for the speaker output , try and give them a gentle tap with your finger it may work for awhile , but you need to replace , is not a simple job , you have to dismantel the amp to get to the soldering side of the board.
Taher
SOURCE: loss of one channel to speaker
when you say switching input wires you mean your source? that you switch it? you only have switch problem, it is mechanical type swutch need to clean only, if still possible. i dont know if you can find replacement.
SOURCE: left channel cuts out intermittently
Any good at sodering?
You have a bad solder joint somewhere!
Testimonial: "never thought of that! I just presumed it had a faulty component somewhere. Excellent advice. Thanks "
