HI I HAVE THE ALCATEL 0T-800 IT WAS ON TESCO NETWORK BUT I KNOW HAVE IT ON VODAFONE. I WANT TO KNOW HOW I CAN INSTALL MY WAP SETTINGS SO I CAN USE INTERNET.
Hi, I have a Nokia Lumia 800 for a couple of years now and very happy with it. Lately I noticed that it doesn't charge very well. Do I need a new Battery?
As far as I can tell, Your phone is from vodafone and you are trying to connect it to a different carrier's internet. If this phone is unlocked, you need to input the correct WAP/Mobile internet settings for your current carrier.
If this phone is not unlocked and cannot access the internet of your current carrier, Phone your provider and ask them to push OTA settings to your phone.
Hi, To get GPRS/MMS setting, you need to contact your service provider through phone or go directly to their office. They will send you the settings for your model. You will receive service settings in the special text message called as smart message. Please save the settings to your phone and set it has default settings. Then you can start using the GPRS/MMS in your phone. Thank You
We can provide remote unlocking codes for 99% of Vodafone-UK handsets.
There is no need to send the handset to us, all we need is the IMEI (serial number) of the handset which can viewed by pressing *#06# on the handset keypad.
The cost for this is £10 or €12 and your unlock code is returned within 48 hours, although usually alot quicker, typically within the hour.
Drop us a mail at sales@phonezonescotland if you want more information and we will be happy to help.
Regards
Joe @ PZS
UK WAP gateway settings The following table shows basic WAP gateway setup information for the main UK mobile phone operators. The menu options differ between handset manufacturers. Some of the common menu fields explained:Bearer type: There are two types: GSM or GPRS. GSM works by dialling a dedicated WAP dial-up number and should work on any WAP-enabled handset. GPRS is a newer technology, and only works on selected handsets. GPRS is an always-on service that is billed per-kilobyte, and not as GSM, which is billed per-minute.Dial-up number - The telephone number that your WAP browser needs to dial to connect. (Not required for GPRS)
GPRS APN - If connecting over GPRS (as opposed to dial-up), you need an Access Point Node address, so the network knows where to direct your request. See our GPRS for full UK GPRS settings
Username and password - Note that these are case sensitive, and should be typed in as shown
Gateway IP details - WAP works by routing traffic through a Gateway that handles optimising the content efficiently. The address is made up of a series numbers separated by dots. This may also be referred to as the WAP Proxy Server address.
Homepage - This is the main page provided by a network operator... The front-door for access to content provided via your network operator
Connection name::"Give any name" Moden:: select "Cellular line (gprs)" Select "Next" Access point name:: "portalnmms" select "Next" Username:: (blank) Password:: (blank) Domain:: (blank) Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes 1.) This network connects to the internet 2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced" Select "advanced" Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok" Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection... When internet is connecting it ll show "Connecting to GPRS" You ll be getting "locating" and "opening" and the webpage
