Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
Posted on Feb 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a linksys e1000 and a Comcast hook up. The router purchased on5-24-011 from Best Buy. For the last seven days I have had to disconnect the power , wait ten seconds and plug it back. It will then connect. If I close my hp Pavilion and the open it again the same day it works fine. Bob
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Feb 09, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263303
Points
2023
Go to www.hp.com select support, enter the model number HP Pavilion xxxxx and run diagnostics.
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on Jun 18, 2009
SOURCE: cisco 1811 router freez
replace your router, got a problem with the board...
govinda123
Prashant M
  • 2278 Answers
  • Posted on Oct 15, 2010
SOURCE: Hi! Bernie here, I have an
E1000 router is not a dual band router.
It works only on 2.4 GHZ wireless signal.
You can try changine the wireless channel on the router.
If you have installed the Cisco conect software on your computer, then open the Cisco connect software. Go to router settings. Click on advanced settings. It will open the setup page of the router. Go to wireless tab.
Set the configuration view to Manual.
change the channel to 11. See if that works.
If not then change the channel to 1 and check it.
Click Here for more information about the routers and network
Computer hardware and networking support
  • 4281 Answers
  • Posted on Mar 06, 2011
SOURCE: can anyone provide me with the easiest way to hook
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Connect internet lan cable from modem to router's WAN port. Let me know if you need further assistance. Thanks for using FixYa.
Anonymous
  • 94 Answers
  • Posted on Mar 07, 2011
SOURCE: I hooked my linksys E1000
you may need to sign in manually,those tvs sometimes dont pick up dns addresses of routers automaticallty
plug in your cable into your laptop
go to start/accessories/command prompt
type in ipconfig
scroll up till you see ethernet
take down your ip4 address,itll look something like this xxx.xxx.xxx.xxx (change the last number to something in the range of 1-250) your subnet mask ad default gateway
plug back in your line to your tv,go to manual enter settings
enter in your ip (with the number changed at the end) your subnet mask and your default gateway number for your dns/gateway if required
if you need more help try customer service on the samsung american site,theyre really good at answering any quick email queries :)
Anonymous
  • 10 Answers
  • Posted on May 11, 2011
SOURCE: manual for linksys e1000 how do I connect router
You can either connect an Ethernet cable from the router to the built-in Ethernet jack that most machines have OR you can install a wireless (Wifi) adapter in your computer and follow the instructions to set up a wireless network...
Need to add another computer to my Linksys E1000 but lost the CD
You don't need the CD. Post the make, model of computer and the OS on it.
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
I just recently moved to a new location. We signed up for AT&T, and just recently purchased the Linksys E1000, and the modem model# is U10C018. My computer is connected through an ethernet cable. ...
Most likely this is not a problem with the router, but with the modem or the connection that at&t is providing to you.
I would suggest calling at&t and have them check your connection.
You should check the filters on each of your phones jacks to make sure that they are in place and properly connected. Additionally, you should check the wiring for any damage or poor connections in your phone lines.
I have internet service with Washington broadband in Yakima, WA. Trying to hook up Linksys E1000 router is proving to be difficult....all hooks up fine, but router not recognizing internet...
you may want to make sure that your IPS supports DHCP or you connect using a dynamic IP address. If not supporting DHCP, you want want to login into router to reconfigure it. Here is link for more info. http://www.linksysbycisco.com/EU/en/products/E1000 I have seen similar issues many time. Good luck and let me know.
Thanks
I hooked my linksys E1000 Router to Samsung 3d TV (Wired), but the TV doesnot detect the internet speed, on my laptop (Wireless) is 144Mbps.
type in ipconfig
I purchased your product,(router1000) Hughes Net hooked it to my laptop and now I am trying to connect a wireless adapter to my other computer. Being asked for a password. Where do I find this?? Both...
It is looking for a NetWork Key or password that was set up when your router was installed. That network key protects your network from some one else connecting to your network. You can reset your router where it will forget that network key and when you start it back up it will be an open network not needng a password, but you are going to have to learn how to enter your router's set uo menu and replace that factory setting with another key. Take a look at:
http://www.linksysbycisco.com/UK/en/support/E1000/download and down load what ever you need. You also should read the manual, you can down load if you want to.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
