Question about Adidas adissage FitFOAM Slides ; Boys Girls for Kids
My son wears the Adidas Fit foam slides regularly. They have developed an "odor" which gets worse when wearing them. I have tried to check and see if others have had the problem, but all the answers seem to be for other types of sandals. Would vinegar or baking soda help? I also thought about plain old Lysol spray.
Posted by plewis4545 on
Cee Sy
    New Friend:
  • 75 Answers
Hi there, it may sound funny, but I have tried spraying my husband's shoes with Glade Pet odor eliminator, dried it for an hour, much to my surprise, it eliminated odor in shoes. I hope it will work for you too.
Posted on Jul 07, 2011
Why do Footballers wear shoulder pads?
The shoulder pads to protect the payer from collisions with other players and they are probably the most intricate pieces of equipment that the players wear. Shoulder pads consist of a hard plastic shell with foam padding underneath. The pads fit over the shoulders and the chest and rib area, and are secured with various snaps and buckles. Shoulder pads are what give football players their "broad-shouldered" look.
Jan 14, 2013 | Football
Does wearing glasses make your vision worse? I am worried that my son is wearing his glasses for too long as he is too lazy to take them on and off.
It's definitely not recommended to wear your glasses more than you need to. But wearing glasses doesn't permanently alter your vision, but it can make your eyes 'lazy' by losing the blur adaption ability but this comes back after you stop wearing your glasses.
Jan 10, 2013 | Health & Beauty
In international competitions, what color singlets do wrestlers wear?
In international competitions, wrestlers wear either a red or a blue singlet.
Sep 03, 2012 | Adidas Wrestling
Are mouth guards mandatory in wrestling?
Wrestlers are generally not required to wear mouth guards during competition. The only wrestlers that must wear them are those with braces.
Why do some martial arts students wear both a red and white belt? What is the significance of this?
Wearing both of these belts together signifies that they are somewhere between the 6th and 8th Dan black belt level.
Sep 02, 2012 | Adidas Martial Arts
Well, I wear my men's UGG ascot slippers a lot. I do not wear socks with them when I do wear the shoes. After I wear them, I spray the UGG odor spray in the slippers to prevent lingering odor. However,...
The problem is the heat produced in the shoes. Since they are so warm many people's feet sweat in them making them smell, and the fur makes the smell stay. One suggestions would be to obviously wear socks, that's what I do with my uggs. If you would rather not wear socks then you can try washing them, but you can only do it by hand because the washer may ruin them. Be careful tho because they are easily ripped when wet. If that doesn't help enough then get odor eaters for shoes and use them when you aren't wearing them. If possible many people have started to replace the inserts in their uggs. Click here to see a website that sells these inserts and click here for a website that sells odor eaters.
Feb 16, 2011 | UGG Australia Ascot Slipper Shoes
My 10 yr old son decided to "work " on my mixer ,
Jim, hi- um, you're reading this with your son, right?
Inspect the brushes carefully, be sure that the little copper wire is firmly attached to both the brush and the little disc at the other end of the spring. Clean the brushes well, allow no oil at all to contact them and if they have gotten oil on them (including cooking oil) clean them with a spray can of electric motor cleaner. If you use non-flammable motor cleaner you will have less of a chance of starting a fire, but it's much slower to evaporate. When you put the brushes in, look at the ends and turn the brush so that the hollow worn into the end fits properly to the commutator. The mixer will run with the brushes turned wrong, but it's simply good practice to fit them properly.
Dust and corrosion will accumulate between brushes and their holders, and it's very possible for a brush to not go all the way into position when reinserted. Again, the electric motor cleaner will help- spray a bit down the hole and on the brush, slide the brush in and out and note any stickiness as it reaches the bottom of the hole. Each brush must contact the commutator with the full pressure of the spring behind it and be free to move as the machine is used and the brushes erode. Note that cleaning the holders can take several tries, and if there is crud in the holder the condition will get worse before it gets better, so take note of how the brush moves, especially at the bottom of its travel. When it's clean you'll be able to hear it contact the commutator when you put it down the brush holder.
If you look down the brush hole you'll see the commutator- the copper bars of the commutator should have a pretty, burnished appearance and the insulation between them should be clean and not standing up above the bars. Black sooty looking deposits and/or pitting indicate that the brushed have not been advancing to the commutator with wear as they should, and arcing has been taking place. This will be caused by dirty brushes binding in their holders or by worn out brushes that are unable to advance or by the commutator bars wearing faster than the insulation between them- a condition referred to as "high mica".
Good luck, and buy that kid some tools- there's a lot more to discover inside that mixer..
lp
Dec 22, 2010 | KitchenAid Food Mixers
Adidas adissage FitFOAM Slides ; Boys Girls for Kids Logo
634 people viewed this question
Top Adidas Clothing Accessories Experts
Marvin
Marvin
john h
STEVE SPAM REMOVER
Are you an Adidas Clothing Accessory Expert? Answer questions, earn points and help others
