Question about Lexicon Mx200 Reverb Delay 1u Effects Processor
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
Posted by jockbyrne on
Eze tom
    New Friend:
Hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Posted on Apr 08, 2012
Reverb only in one speaker
Have you checked the cables, jacks, pan settings etc?
There may also be damage to the potentiometer.
Mar 22, 2015 | Lexicon MX200 effects unit (with )
Lexicon mx 200 preset knob frozen
If unt was dropped, look for broken PC board in the vicinity of the rotary encoder. Also look at solder connections to make sure they are sound. A little contact cleaner applied to encoder through an opening so the spray gets inside will help clean contacts. If the knob itself is hard to turn, the shaft is likely bent, and there may be damage to the encoder itself.
Oct 27, 2012 | Lexicon Mx200 Reverb Delay 1u Effects...
The unit itself is generating too much noise(hiss). some effects are noisier than others but overall noise level is unacceptable. all the product reviews say how quiet this unit is. tried changing signal...
Check that: You are using BALANCED interconnection lines (TRS or XLR) everywhere. Low quality cables can cause or let in noise and hiss.
Check that ALL, and I mean ALL interconnected equipment is powered from the SAME receptacle or power conditioner.
Check that you are not using a noisy source or recording system like the internal audio of a PC for instance.
Short the inputs to ground and see if the output noise goes away. Some effects are noisy because the inut signal after effects gets added back into the output.
You haven't described your setup and without that information there is not much more I can add. Ferreting out noise is one of my specialties. In general your input level should NOT be too small as this leads to less signal to noise ratio due to digitizing noise. Look at the Lexicon specs to find what the levels should be. Without the description of your setup I can add no more...
Jul 16, 2011 | Lexicon MX200 effects unit (with )
Hi! I just recived a Lexicon Alpha desk top and i cannot find the actavation code. Therefore i cannot activate the recorder "i guess" or can i?
There is no activation code. You will need software that handles I/O sound device other than the built in audio of the PC. This device is sometimes delivered with either Sonar home edition or CuBase.
Jun 13, 2011 | Lexicon Alpha Personal Recording Studio
I have an I-Onix u42s which worked great up until today when I turned it on and it's not picking up any input sounds. I tried every input and no sound is coming through. I changed nothing on the...
Probably the sound and devices settings in Windows control panel have been clobbered back to the computer audio instead of the Lexicon. Check the device defaults in "Audio" and "voice" tabs in the "sound and devices" in the Windows control panel.
Jun 01, 2011 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
Hi, I'm not sure of the polarity of the Lexicon mx200. I have bought a multi tip transformer & it gives 2 options of outside + or inside +, do you know which is which please, I don't want to fry it!...
DO NOT use universal adapters to run these devices. Accidents are too easy and often the universal devices do no have adequate filtering. You are off on the wrong foot to start with as this unit does NOT have a polarity since it REQUIRES an AC adpter, not a DC one. What you have WILL NOT WORK. If you have connected it, it should NOT have caused damage, you just won't get any audio out, even if the unit lights up on one polarity. The unit generates both polarities inside using the AC input.
Here is an example of correct adapter: http://lcdpayless.com/productpage.php?productId=5793
Apr 25, 2011 | Lexicon MX200 effects unit (with )
Lexicon alpha does not install with XP SP1a, error = "Cannot start device code (10)" Drivers from disk are installed, device is listed in device manager with a yellow exclamation point. Do i need...
You should be at SP2, but that MAY NOT be the problem. One thing to check is if you are supposed to have the device connected when you install the software... in SOME cases doing it with or without connection will affect the outcome. Also make sure ALL virus/spyware/popup blockers are disabled during install.
Before using this device, make sure that going to the control panel and looking at the "Sounds and Devices" shows that the Lexicon is the inout and output device for all the tabs within that window.
Dec 16, 2010 | Lexicon Alpha Personal Recording Studio
I have the cubase le 4 and, everything installed fine but when i went to record nothing was happening the cursor moved across the screen but wasnt picking up any sound. i also got a message saying that the...
Try downloading Asio4all at http://www.asio4all.com/ and carefully following their instructions. There is good information under the FAQ/Troubleshooting section on their site. Id also recommend joining Recording Review for some great info. I think you can reach them through [email protected] Hope this helps.
Jul 09, 2009 | Lexicon Lambda 4x2x2 USB Audio Interface
Lexicon Mx200 Reverb Delay 1u Effects Processor Logo
306 people viewed this question
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
