SOURCE: Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
SOURCE: printing blank pages
Check that the cartridges are seated correctly. Also clean the contacts in the casing that the copper portion of the cartridge sits against.
SOURCE: Printer just stopped printing, new black ink
Solved this problem by going out and buying a new printer!!!!!!!!!!!!!!!
SOURCE: The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Cleaning the Print Cartridge Nozzles:
1.
Open the Lexmark Solution Center. Click Start > Programs or All Programs >
Lexmark 1300 Series. Select Solution Center.
2.
From the Maintenance tab, click Clean to fix horizontal
streaks.
3.
Click Print. A nozzle page
prints, forcing ink through the nozzles to clean the clogged nozzles.
4.
Print the document again to verify that print quality has improved.
Using the control panel
1.
Press Menu.
2.
Press the down arrow button until you highlight Clean Cartridge.
3.
Press Select. A nozzle page
4. Print the document again to verify that print quality has improved.
If the yellow ink is not printing here's what you
can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to
select Test Print, then select Print Quality press OK and press
Black or Color START. Check all the colors including the black & check if
there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select
cleaning press ok
3. Press the up or down arrow key to select Color press ok and press
Black Start.
*After the cleaning process the printer will ask you if the quality is
OK, press up or down to select yes or no, and it will ask you whether black or
color is ok, once you have selected you're answer press Black or Color START to
print another test page. Compare the 1st and 2nd test page if it's
improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
