You have a weak or failing thermostat ,, you can check them by doing this Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. be sure machine is unplugged before doing any electrical tests
Thank you for the advice. My husband can test it when he gets home from work.
