Question about Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF437B/37 sound doesn't work sometimes, but comes back when we turn the unit off and then back on - is something going wrong - or are we doing something wrong? we use it a lot to stream movies with a laptop on the PC input
Posted by comsol on
4 Related Answers
Anonymous
  • 8619 Answers
SOURCE: Magnavox 37MF437B/37. Been a great
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
SuperTech-11
Norman Skinner
  • 1591 Answers
SOURCE: 37mf437b/37 will not power up just makes chirping
Look for more caps, and start checking transistors.
See my tip in tips and tricks for checking transistors.
Posted on Mar 06, 2011
Anonymous
  • 1622 Answers
SOURCE: Magnavox 47MF437B/37 works fine until
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Posted on Jun 12, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Posted on Dec 20, 2012
37mf437b/37
Sounds like back-light inverter board fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
1helpful
Magnavox 37MF437B/37 keeps blowing fuses
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
1helpful
2answers
I need help in identifying whether or not my magnovox is 720p or 1020p. The ID # is 37mf437b/37 and the serial # is bz3a0722610855
Google the model number--owner's manuals are available on the internet for free.
This model (37MF437B/37) IS A 1080P SET.
If you need more information or advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for free.
SD TECH
2answers
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
LCD television (Magnavox 26MF231D/37) is turning on and off on its own, with picture going out in such a way that the images disappears then grey lines appear across screen and loud sounds come out of the...
I have the same problem.
and so do MANY others:
another fixit post tells you to remove the back and take off a metal part: http://www.fixya.com/support/t255942-power_cylcles_off
This is the older brother: A lot of the reviews describe your very problem.
http://shopping.yahoo.com/p:Magnavox%2037MF231D%20Television:1994315520:page=user-reviews
Magnavox should do something about this!
29helpful
8answers
My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
