SOURCE: After one print, it goes Offline
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Good luck
SOURCE: says it's offline when connected to my macbook
RIGHT CLICK ON THE PRINTER ICON AND SET IT AS A DEFAULT PRINTER, THEN TRY IT AGAIN, IF IT DOES NOT WORK THEN RELOAD THE DRIVERS TO GET IT WORKING
Testimonial: "After downloading the software (once again) and then installing hp driver updates, it worked! Thanks!"
SOURCE: 2040 keeps telling me it's offline disconnected
Your drum cartridge may be used up. Replace it.
SOURCE: My computer says my printer is offline but the
Uninstall the printer, if using USB, move the printer to a different USB port, then reinstall the driver.
