see this causes and fix it. God bless you
First you will need to identify if you have a direct drive type or a
belt drive. The later is obvious if you have belts under your machine it
is a belt drive, if not it is a direct drive. Also there are 2 basic
agitator types with some variances among them. The 2 piece and the
single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out
over time. They also break and can cause noise. To inspect and
replace the agitaor dogs follow video.
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE
types have a coupling that gets stripped out and the older GE type has a
spline directly on the agitater that gets stripped out. You will need
to remove the agitator. The dispenser usually pulls right out. This will
give you access to the bolt that holds the agitater down. Remove the
bolt, then place your fingers under the agitator and pull up. This can
take some force. A belt slid under the agitater can also work. Once off
you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check
for black soot from belt wear. Replace if it has excessive wear or
broke.
Motor Coupler
This is a fairly common problem with direct drive machines but
inexpensive and easy to replace. The Motor Coupler transfers power from
the motor to the transmission. The following video will walk you through
the
replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive
remove the motor
and then turn tub inside. If it spins freely with no noise the problem
is elsewhere. If it is noisy it needs replacing this is expensive and
depending on the age of your machine you may not want to replace it. On a
belt drive remove the belts and spin tub.
