No picture on screen but power supply is OK
Here is a couple of suggestions for this monitor. 1st check your connection to the computer.
make sure the VGA/HDMI/DVI is properly connected. 2nd check to see if the monitor is setup
to use the right source. Some monitors do this automatically others may need to be manually set.
either look for a button to do this or bring up the monitors menu by hitting the menu button. If the monitors menu button does'nt bring up a menu when the computer is off then the monitor is probably bad.
If the monitor works until the OS boots then goes black. The video card in your computer is set up
improperly with the monitor . In Windows hit F8 as the OS boots this will cause the computer to boot in safe mode. Once in safe mode right click on the desktop then go under properties then settings and change the display option to the correct monitor. You can also go to the device manager in my computer under system information, hardware, device manager and change the monitor here also.
