SOURCE: driver for Nikon Super Coolscan 4000 ED scanner
Here u have and please if it was helpfully for u rate this solution as solved:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Nikon-Super-Coolscan-4000-ED-110.shtml
SOURCE: Nikon Coolscan 8000 ED Film Scanner
Jim try looking into the vuescan software. It comes highly recommended and is priced very reasonably.
Hope this helps, Rose
SOURCE: Nikon Coolscan III LS-30 repairs
I had the same problem. You must remove the cover on the scanner. The reading unit shuld be moving on two metalleaders. It was the oil on them that was dry so i had some oil on and helpt it moving with my finger. Now its working again!
Good luck! Bjarne
SOURCE: Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
SOURCE: need driver for Nikon super coolscan LS 5000 ED
Go to Nikon's official website, then search for support. You'll be able to download all the drivers and Nikon Scan software. Hope this helps.
