Epson Stylus Photo R220 InkJet Printer Logo
Question about Epson Stylus Photo R220 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
Posted by fblowe336 on
Anonymous
    New Friend:
  • 84 Answers
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Posted on Jul 06, 2011
2 red flashing lights on epson r220 printer - Epson Stylus R220 Photo Printer
See cd/dvd guide first if it is open please close it and restart ur devic.
Normally indicates the ink counter needs resetting the following utility will do it make sure you read AND FULLY UNDERSTAND THE INSTRUCTIONS.
http://www.ssclg.com/epsone.shtml
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
2helpful
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
1helpful
2answers
1helpful
Blinking red lights
I have a canon s630 and the yellow light blinks 7 times and green once, what is causing this and can i reset this printer?
1helpful
5answers
Red Flashing lights
hi dear
try to resetting your catridge
or here
http://inkjetprinterhelp.us/epsonSSC.html
oke
i hope your problem clear
good luck
Printer won't stay on
Your printer need reseting
Ask to epson manufacturer if they have R220 reseting CD.
2answers
Epson r220
DOWNLOAD THIS EPSON PRINTER SERVICE UTILITY FOR FREE AND RESET THE INK MONITOR
Top Epson Office Equipment & Supplies Experts
Mehandi Husain ...
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
