SOURCE: K750i "Insert SIM"
do all the contact pins on the phone reach the simcard?
you can try to pull them up a little bit carefully.
SOURCE: Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
This will help you
http://assets.twacomm.com/assets/pdf/4230.pdf
SOURCE: panasonic kx-t7453, night mode message programming
Do you mean have calls transferred to voice mail? Go into system programming and change 408 (DIL 1:1 Nite) to point to the ext of the voice mail port, which depends on your system. That number is found in 118
SOURCE: Programming feature access keys
These Keys may be set as line keys instead of feature access or not tagged as "feature access" in the programming, also you can only have so many feature access keys... 8 comes to mind but I could be wrong, some features can be programmed permanently onto a button in the main programming so you can free up some more feature access (user programable) buttons.
SOURCE: initial programming needed
under settings, go to phone settings, then NAM select, then select NAM1
