Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive Logo
Question about Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive
My Samsung DVD writer's Tray open autumatically and some times closes and open again. Sampath
Posted by sampathsuw on
Brian Sullivan
  • Samsung Master
  • 27,725 Answers
The drive might be getting intermittent power
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jul 06, 2011
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
3helpful
My cd tray wont stay closed. it opens a few secons after i close it.
Don't worry dear user this problem is creates when we using a long time are cd/dvd writer but if have this type problem please reinstall your cd/dvd driver and your problem can be solved........
2answers
I have samsung dvd writer, when i open it the tray gets automatically closed. help me out!!!
Dear it means that your dvd writers belt is scuffed from somewhere now either you have to change the belt which can be done by only at service station or through any hardware engineer
1helpful
My dvd-writer/cd-writer combo will not open?
look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
Fosg2000
I have a Lite-On DVD writer that will not open unless disk is in.
The problem is with ur DVD Writer Tray, Some of the reason ur dvd writer tray get jammed. For the temporary purpose you can use the manual eject pin hole Technique.
2helpful
2answers
My dvd writer opens and closes automatically it wont stay open
This occurs when there is dust accumulated in the inner part of the tray. Send it for a service
My DVD ROM does not burn some cd,when it tries to burn the tray opens its self.how do i stop the tray from opening and closing its self automatically
Either the CD is full or the quality of the CD is inadequate to burn it with your CD writer.
Try a good quality CD, or lower the writing speed and make sure it is an empty CD.
Jules
Dvd writer
If you push it in with the hand maybe you get the sistem out of time
20x Dual Layer LightScribe DVD Writer ±R/±RW/RAM tray opens every time i power my pc up and i have to physically hold it closed
*just disassemble ur dvd writer and there is a light whole in left of the tray in that put any pin or lead and scroll round and try by assembling again ur dvd writer
Samsung 52x cd writer
use memorex brand cdr they are the most compatable (readable media ) to many cd& dvd writers .
the reason the cd writer dosent open often is because its usually trying to read poor quality media use good quality memorex cdr you will see a big difference in performance.
Open Questions:
See all Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive Questions
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
