SOURCE: Need Repair for OL-3000
All programing functions are controlled on the main (stationary) board. All display functions are controlled on the Rotor (spinning board.) Here are some steps to take if you are having display problems. Remove the three mounting screws that hold the rotor to the motor shaft. The LED display board is attached perpendicular to the rotor board and is soldered to the rotor board. Over time, the connections break due to the centrifugal force of the spinning rotor. CAREFULLY, with a low amp solder iron and a fine tip, re-heat the board to the display. That should solve the problem. If you were a bit sloppy with the solder, remove the solder with a fine wick and try again!
SOURCE: Olympia Globe Caller ID
I just printed a manual in pdf form go to,http//smarthome.com/manuals/5109.pdf
SOURCE: olympia caller ID globe
i dont know what is the answer....im so sorry for that...i have question...who post this question?
