I hope its usb cable my have some problem..... try to purchase a new car reader to insert memory card into it and plug it to pc via usb port..... then also if you face same problem then check you usb port drives and install them......... to rectify this problem.... some times firewall also will not accept usb so switch off firewalls while plug in device cable........
Supported windows Operating system
Windows 98 Second edition(SE) Windows Me Windows 2000 Service pack 4 Windows XP SP 1 and SP 2
Canon PowerShot A430 has no update about the new driver software for windows 7
Try doing this direct transfer in your computer
1. Connect the camera to your computer using the supplied USB cable of your camera.
2. Set the mode dial to (playback) and turn on the power. The camera and computer will be able to communicate.
3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow]
4. Download the images. * Download the images using the camera or the computer. * By default, the downloaded images are saved into the [My Pictures] folder.
** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another.** Issue on the operating system compatibility.
change it to xp service pack3
and still problem continues it is due to the audio port connection
device not being recognized plz repair it using your warranty.....
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
If nothing else works, try using a usb card reader to get the pictures into the computer's hard drive. A nice usb card reader is available in all electronics stores such as Best Buy, Walmart, RadioShack, and so on.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Check whether the software CD you received with the camera, support the Win XP OS.
In case it doesn't, go to the Canon web site and download the relevant drivers for you camera and OS.
did you download the canon download app or are you using the installed pc generic camera download app? it will make a diference if the computer cannot reconsile which too use. let me know and we can go from there
