AT&T Motorola RAZR2 V9 Cell Phone - Purple Logo
Posted on Jul 06, 2011
@bootup, it says Bootloader 05.80 etc... Connect to USB Data Cable...can't use the phone
How unlouck bootloader
To unlock the bootloader on your Lenovo Tab3 7 Essential (TB3-710I) tablet, you need to follow these steps:
Note: Unlocking the bootloader will erase all data on your device. Make sure to backup your important data before proceeding.
  1. Enable Developer Options on your device. To do this, go to Settings > About tablet > tap the Build number 7 times.
  2. Enable USB Debugging. To do this, go to Settings > Developer options > enable USB debugging.
  3. Download and install the ADB and Fastboot tools on your computer.
  4. Connect your tablet to your computer using a USB cable.
  5. Open a command prompt window on your computer.
  6. In the command prompt window, type the following command and press Enter: adb reboot bootloader, This will reboot your tablet into the bootloader mode.
  7. Next, type the following command and press Enter: fastboot oem unlock, This will unlock the bootloader on your tablet.
  8. Once the process is complete, reboot your tablet by typing the following command and pressing Enter: fastboot reboot. That's it! Your Lenovo Tab3 7 Essential tablet's bootloader is now unlocked.
How I can connect my Samsung GT-E2152 mobile with computer through usb cable
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
How to connect via data cable?
Materials:
USB data cable.
PC Suite mobile software.
What is a data cable?
A data cable is a long cord, which connects your computer with your cell phone in order to share data between them. The data cable transfers electrical signals from cell phone to computer and computer to cell phone.
What is PC Suite mobile software?
You can buy the following commercially or on eBay for about $10. It contains everything you'll need.
All the best,
Ben
2helpful
Screen is blue motorola logo says bootloader usb init when try to shut off black screen says verizon tried taken battery out same problem. Thanks
Your phone is starting in flash mode..You need to have either p2k phone tools or motorola phone tools..you can get them from www.modmymoto.com. once you have the software on your PC connect your usb cable and reload your phone
1helpful
2answers
I'm getting a bootloader usb init screen
Your phone is partly fried. It needs to be re-flashed. You can do it with a USB cable and the proper software....Google "bootloader USB" for some help in finding the software. One thing to try, hold down the "*" and "#" keys while powering up the phone, this could possibly help, but I doubt it.
Good Luck!!!
1helpful
Screen is locked with words & numbers on it
Your phones boot loader is corrupt.It will have to be re-flashed.
Razr v3 bootloader problem....HELP!!!
Boot Loader Problem in Moto RZR V3i.
IMEI - 35770201214927
Phone doesn't open. if turns on shows message: Boot loader A3.CC Err>A5,6935.2E Battery OK OK to Program Connect USB Data Cable it doesn't continue anywhere.
something seems to be wrong with your bootloader. what you need to do is
1. go to www.modmymoto.com and download the A3.CF bootloader which is the latest bootloader from motorola.
2. once you've done that, download the latest version of RSD Lite (you'll find it on google).
3. Install RSD Lite on your computer and open it up.
4. After the program recognises your phone, look for the bootloader that you downloaded and hit start. DON'T UNPLUG YOUR PHONE TILL THE ENTIRE PROCESS IS COMPLETE.
This should solve your problem.
This process can be risky, but it's the only way it'll work. For more information on installing the bootloader with RSD Lite, please read through the forums at www.modmymoto.com carefully.
Motorola v6
re format your v6 to software...
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
