Question about Kodak EasyShare C180 Digital Camera
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around just in case. No luck. I used it a few weeks ago and had no problems at all.
  • Kodak Master
  • 4,738 Answers
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Jul 06, 2011
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
No power
You've done all Kodak asks you in their trouble shooting guide. As its less than a year old, I would recommend you go back to either Kodak or your retailer and request a refund or replacement under warranty.
Apr 13, 2010 | Kodak Easyshare M753 Digital Camera
My kodak easyshare lens keeps shutting off. the lens goes out and in and off. the camera is less than a year old
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 11, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
My kodak md1063 digital camera switches on then straight of,have fitted new battery no difference.
My kodak Easyshare C653 camera is 2.5 years old when suddenly did this a few times then completely refused to turn on at all. Research showed me that this is a firmware issue in Kodak cameras. Kodak website said it will look at it and try to fix it for minimum $70 which is not worth it in my case as I paid $130 for the camera brand new 2.5 years ago. So either pay the $ for kodak to fix or buy a new camera is the solution. I am buying a new camera but it won't be a kodak this time as I want a camera that last years and won't go dead after warranty runs out.
Sep 01, 2009 | Digital Blue EasyShare MD1063 Digital...
Kodak easy share digital camera m863
I have a Easy Share M863 and have had it less than a year. It was working great and then last week I tried turning it on and it would not open. I thought it might be the battery needed charging so I did that. It still will not open. I contacted Kodak and they told me they would give me 15% on a new digital camera. That is not what I wanted. My camera is not even a year old. It should have lasted longer I think.
Jun 08, 2009 | Kodak EasyShare M863 Digital Camera
My kodak easy share c433
Are you using alkaline batteries? The Easy Share hates alkaline batteries. Try NiCad or Lithium.
Oct 16, 2007 | Kodak EasyShare C433 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
561 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
