Question about Dometic Refrigerators
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy cold,then suddenly stop cooling,the gas flame is perfect,and i try plugin to 240v and the element work to producing plenty heat,can you help? thankyou
Posted by wiadrowski66 on
5 Related Answers
Anonymous
SOURCE: Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Posted on Oct 09, 2008
Anonymous
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
Mike Inman
  • 219 Answers
SOURCE: Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Posted on Mar 19, 2009
Anonymous
SOURCE: Chescold caravan fridge 3 way
Yep same prob as my Chescold model RC1180. I pulled the entire gas circuit apart as the fridge works well on 240v haven`t yet sussed the 12v.
I suspected the thermostat ( on the gas side ) there is a tiny jet on the side of the aluminium block at the base of the electric thermostat, also another springloaded 'valve' at the bottom of the aluminium block.The ' valve' is actuated by the thermostat Dial, as it screws a pin down onto a plate which departs from an O' Ring seal letting gas into the chamber where the tiny Jet is seated.This tiny Jet meters the gas to the Pilot burner.
Anyway ' That' wasn`t the problem! lol
The Problem was a 'Clogged Pilot flame Jet'
Fix..... I stripped as piece of fine electrical wire 12v and cleaned the jet out. It is a # 26.
The Jet itself looks like it has been 'Stamped' out rather than Drilled, this may account for some fridges working better on gas than others as there seem s to be some distortion on the Jet Orifice. I will buy a new Jet and a #26 drill and replace the original one.
I am just testing the fridge on Gas now...going like a Trojan... bonus is ive got a little 3 sausage hot plate over the Gas exhaust and am cooking dinner while the beer is getting colder !
K
Posted on Apr 12, 2009
Anonymous
  • 3 Answers
SOURCE: all of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Posted on Apr 18, 2009
The fridge section of my fridge/freezer is not working.l have upped the temp control to coldest but still does not work. The freezer section is fine. What could be the problem
Hi
It sounds as if the defrost element needs replacing in the freezer compartment.This impairs the circulating fan causing the fridge temperature to rise.(and the freezer to work overtime)
How do I set my chescold to freezer mode do I put the thermostat on low or high
1) always list the brand name "chescold" AND the model number when you have a hardware query. Then google both or go to the brands homepage and see if they offer support.
2) If this involves a chescold operating on bottled gas, regardless of where the thermostat is set, it will like freeze as long as the gas lasts. Yes, even if the thermostat is set to OFF. If the freezer is being chilled by electricity, the thermostat WILL determine the temperature. My best "guess" if the chescold is powered by electricity, a high setting means increasing cold simply because who would make a freezer so that if you powered it to its highest setting, it would thaw out. I generally think increasing a setting means increasing the effect of the machine, be it a freezer or a heater. But it "ain't necessarily so."
3) Usually with freezers, the "higher the number" the colder the freezer will get. But it is a gamble unless you have received proper instruction.
I have acquired a finch b533g 3 way fridge but without instructions. Can anyone help with simple steps for 240v and 12v . The gas is covered by factory stickers. Thanks in advance
as this product is rather ancient, manual is difficult to obtain, i can suggest enquire in sports stores which still sell this product, manufacturer is obscure, but fridge itself is one of teh best and cheapest on the market! new one is sold for anything between $500 and $800. it was first manufactured over 25years ago... have friend which is still using it...
have short preview for it:
http://www.wholesalervequipment.com.au/chescold-portable-fridges/freezers/dometic-b533-575-12v/240v-33ltr-lpg-finch-fridge/prod_14.html
and i think this will be best manual for it:
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0CGAQFjAH&url=http%3A%2F%2Fernie.awa.com.au%2FArticleDocuments%2F1168%2FUser%2520Manual%2520Memphis%2520TWF45L.pdf.aspx&ei=WwTaVKvxHZLd8AX5lYCgBQ&usg=AFQjCNH26A-FH7kUw55NIz3gZBzjHGezkQ&bvm=bv.85464276,d.dGc
hope this will help you - do not forget to vote...
I have a 1995 model chescold 3 way 39lt (brown) does it matter which way the internal 12v wires are connected to the plug on the back of the fridge, as they are the same colour and not marked positive or...
if the 12 volt,is A/C (alternate current, check with volt meter) ,then you can connect it any way , but if these are D/C , then you have to find positive and negative wires ,it look like 12 a/c that does not need marking
2helpful
2answers
Chescold rc1180 users manual
It appears that your brand branches off to many first name brand's like=> Chescold RC1180, 50 litre, 3 way, (12v,Gas,240v)
Here is the user manual=>
Combi Box 3 Way Fridge & Freezer RC1180
sea_breeze_111.jpg Caravan's Plus
RC 1180 EGP Fact is I could see so many different versions I am leaving you with a few extra divisions of Dometic. Should you need more answers please let me know, Thanks, Sea Breeze Please rate this solution. Sea Breeze
1helpful
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
hope answer the question
thank you
please vote!
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
4helpful
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
6helpful
Chescold caravan fridge 3 way fridge, (out on the bench not in a van) works well on 240V but not on gas. Pilot looks good, fridge is level, I have tried inverting the fridge as suggested. No luck. I can't...
K
Refrigerators Logo
Top Dometic Refrigerators Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Jay Finke
Jay Finke
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
