Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem? This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet. something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection. If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01 or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
Posted on Oct 17, 2007
SOURCE: Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Posted on Jan 07, 2008
SOURCE: Belkin N1 Wireless USB Adapter
Hi Emma,
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Please let me know how you make out.
thanks
Posted on Jan 21, 2008
SOURCE: Hi, My Wireless adapter -Belkin 802.11b is stopped
First check whether the adapter is working or not?
In the device manager you are able to detect the adapter, that is a good sign.
When you go to the adapters properties, does it say working properly,
If it is , then you just need to connect to the wireless network and the light will lit up
Click Here for more info
Posted on Oct 07, 2009
SOURCE: cannot connect to internet
Ring up your server provider its free -
Here's the US and UK's numbers.
If your countries none of them please comment back with your country and I'll get your counties freephone for belkin for you.
UK
0845 607 7787
USA
Hope I helped
Dr Reed
00 223 5546
Posted on Apr 07, 2010
