Question about HEWLETT-PACKARD Office Equipment & Supplies
I have a HP PSC 1510 all in one printer. How do I keep it from printing a sample page every time I turn it on ?????
Posted by sandman31 on
    President:
  • 2,992 Answers
The printer probably giving you an alignment page each time it starts up because the catridge alignment wasn't completed. Place the sheet face down on the scanner glass and press the scan start button. This will finish the process and the printer will remember it was done, and no longer print that page every time. You can download a copy of the manual here from HP if you need one for reference.
Posted on Jul 05, 2011
1510 black cartridge can print how many pages
There are 2 black cartridges which can be used in PSC 1510 ie 92 and 94
92( 5.5 ml) can print around 210 pages if its being used with HP 93 ( Tricolor) cartridge
94(12 ml) can print around 470 pages if its being used with HP 95 ( Tri Color) cartridge
You can also check it on HP Website click here to check on HP
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
How do l stop alignment page printing each time l
Don't turn the printer off. Sitting idle, it uses hardly any power at all.
Apr 26, 2010 | HP PSC 1510 All-In-One InkJet Printer
Printer prints test page before every print job
replace all carts with new HP carts to get a sucessful alignment
Apr 20, 2010 | HP PSC 1510 All-In-One InkJet Printer
Prints test page every time i switch on
you have to print test page then alin the page up withthe bars and letters, you have to do this each time you put in a new cartridge, use he menu key to aline the keys.
Jan 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
How to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Nov 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
Keep getting error message from HP PSC 1510 all in one...asking to align, but aligning always fails
For completing alignment both print cartridges need print in good quality.After the alignment page is printing put it on the scanner glass to way as shown on the page and press scan button.If not help replace the cartridges and try again.
Nov 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Test printing made every time when the machine (HP PSC 1510) turned on.
I used to have the same problem with the 1510 and other HP models. The solution is not to have any paper in the tray when you turn it on. When the error flashes up, hold the cancel/resume button (it will be flashing orange on the printer) until all activity ceases in the printer. You can then cancel the message on the PC and load the paper when you are ready to print.
Pete
Apr 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 PRINTER
first ckeck out the your cartages are ok and then when you start the printer them it print the alignment page then put it in the scanner and scan it your problem will be surually solved
Jul 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-in-One Printer/Scanner/Copier, how do you stop the sheet it prints out at start up.
Here is link to the fix.
Each time a cartridge is replaced, it tries to do a test page.
Please read the link and let me know if you have any more problems.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00473778&product=428800&dlc=en&lang=en
Jun 17, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printing test page every time the printer is turned on
if the menu does not have print test page option.
then leave it on. it will likely go to sleep
this is all I found on it
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&lc=en&cc=us&lang=en&dlc=en&product=428800
Apr 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
103 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
Lawrence Oravetz
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
