Just in case
:click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
if your computer came with
a motherboard disk the drivers could be on it
sometimes the wires inside
the cable will be damaged due to bending or stretching or placing heavy
equipment upon the cable,
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again,
check the USB leads that
attach to the motherboard usually red-white-green-black make sure they are
securely seated and have no dust build up on them dust will cause static and a
lot of unforeseen problems also make sure the computers Ram and Cmos battery
are securely seated
hope this helps
test all leads that attach to
your hard drive including electrical extensions,IDE,SATA
the leads from your
((motherboard to your hard drive)) make sure they have a secure connection and
are not faulty or just replace them they could be faulty:
make sure all leads that are attached to your drives dvd\cd have secure
connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a
faulty fan lead can cause this problem follow the troubleshooting procedure a
computer needs all of the data and electrical current to travel through every
working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will
fail before your motherboard or your hard drive check all electrical extensions
make sure they are securely seated even the cd/dvd drives need to have current
go through make sure these :devices are working:
:hope this helps:
