Question about HP LaserJet 1320 Printer
Hi I hv installed hp laser jet 1320 printer in my system but print on both side option is not shown in printer property
Posted by vinnay_iit on
Mark Schmit
  • HP Master
  • 1,915 Answers
Do you have the 1320D or just a 1320. Only the D version will duplex automatically. The base version requires you to manually duplex. If you are sure you have the duplex version, then check the settings in the print driver and make sure it shows that the duplex option is installed. The driver often defaults to no duplexer.
Posted on Jul 06, 2011
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | HP Laser Jet 1320 Printer
Problem: Not able to print mirror image in HP Laser Jet 1320 Printer. Please help. OS: Windows XP Printer: HP Laser Jet 1320 Software: Adobe Pagemaker 6.5
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image checkbox.
9. Click OK, and then click Print or OK in the Print dialog box.
For support call Our Toll-Free 1 888 224 4280
Jan 20, 2011 | HP LaserJet 1320 Printer
I want my hp laserjet 1320 to print front and back
Make sure the manula paper feed slot is closed.
Access Printer Properties or Printing Preferences
Select the Finishing Tab
Select Print on Both Sides
Select OK
Then print the document(s)
Nov 10, 2009 | HP LaserJet 1320 Printer
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Jul 19, 2009 | HP LaserJet 1320 Printer
I have a 1320 printer that just prints blank pages
If ink is ok , then you may need to reinstall printer drivers.
Unplug printer USB.
Go to control panel>>Installed printers and delete existing printer installation.
Reinstall printer driver software using printer CD.
Mar 02, 2009 | HP Laser Jet 1320 Printer
My laser jet 1320 will not print.
hi,
that might be problem with yur printer data cable,
kindly replace it and check.
thanks Ravi
Dec 14, 2008 | HP LaserJet 1320 Printer
HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Aug 05, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
151 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
