Samsung SCH-U450 Cell Phone Logo
Question about Samsung SCH-U450 Cell Phone
I dropped my Samsung Intensity U-450 and the screen turned white. I had recently replaced the lcd in the phone because the previous one was cracked. Everything else works fine, just can't see anything. I've taken it apart and have reconnected all the connections....still white. Think this LCD is bad as well?
Posted by drewsky85 on
Christopher Lozada
  • 1,140 Answers
Still possible, be sure to replace original LCD parts, some class A don't last long.
Posted on Jul 05, 2011
RE: Samsung Intensity II cell phone -The phone will turn on and off. the alarm goes off, but I can not get the screen to come on
There is a flat ribbon cable inside that can come loose or the screen has gone bad. My Galaxy TXT didn't last one year before the screen died. If it's still under warranty and the screen isn't cracked, Samsung will fix it.
My samsung intensity ll wont work because it kept dropping what do i do
take an eraser and rub the battery contacts the battery fits very loose in that phone
White screen
Screen is ng. See if your provider will replace the phone at no charge.
2helpful
Samsung intensity frozen bootblock
okay this happened to my samsung intensity late at night i freaked and did everything i could think of then i went to my moms samsung intensity took hers and my batery out switched them turned both phones on they were fine switched the bateries back and viola it was all better again. try this if it works great please tell more people. if it doesnt i guess it just fixed my phone sorry. hope it works.
Nov 20, 2009 • Cell Phones
7helpful
Samsung tocco 480 screen is cracked/broken
The screen should keep working with the LCD cracked. i.e you should be able to receive calls.
You can find replacement LCD screens for Samsung F480 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/F480
I hope it helps.
Ignacio del Olmo
MY SCREEN IS WHITE
Your LCD screens are cracked. Almost any significant crack will make the entire screen "go white". If you LIGHTLY press on the screen you'll probably see where the crack is (appears as a small black or multicolor line and may or may not "bleed"). You need to replace the screen (at a repair shop, mail in service, or DYI with a replacement screen) or get a new phone. Sorry.
Cell phone dysfunction
I am not sure on your phone but the screen on my wife's u740 turned white right after I dropped it. I had to get a new phone because I didn't look into replacing the lcd first. That was the discription of my problem from verizon was a pressure crack in the LCD. I hope that helps.
Top Samsung Cell Phones Experts
Robert
Steve
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
