How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. Required Tools: 2D to 3D Converter 2D Video to 3D Video>Step 1: Run 2D to 3D Converter in Video Converter 2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. 2D Video to 3D Video>Step 2: Click Video Effect Settings button, and Edit button Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. 2D Video to 3D Video>Step 3: Click Start button to convert 2D to 3D Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
