SOURCE: trying to take the base off my son's 42 inch olevia 542-b12
There are 16 phillips head screws on the back of the TV above the base, remove all of them and the base just falls out.
SOURCE: Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
SOURCE: Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
SOURCE: I am trying to wall mount my LG M197WDP - PZ 19
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
SOURCE: my element lcd tv model number flw1920b just stop
Two capicators on the power supply fail. C300 (680uf 10 volts) and C303 (1500uf 10 Volts). With a little electronics no how and a soldering iron you can have it up and running in a couple of hours. Parts at Digitkey (P12365-ND) and (493-1500-ND) Hope this helps.
