Sounds like main board fault. Contact any service technician.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check the input connections. If Ariel connection, or other video input connection from any external source have loose contact, or wire broken, this type of interference can occur to picture. Gopakumar Gopalan Google
Try your cable box on a different tv set and also try connecting the cable directly into the t.v, if that makes no difference then your tv set may have a power supply problem that was caused by an a.c line surge during that storm.
It sounds to me like you have a bad plasma panel. Unfortunately you may now be in the market for a new TV if you are not under a warranty of some kind. That issue is unfortunately unrepairable because it requires you to replace the entire panel and therefore is not cost effective.
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
if you have a picture the engine is probably ok. this is a common problem with this set.it is probably the main chassis (DM or FMT)
visit www.tv-techs.com
Good Day, scharania;
Try all of these: 1).HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB. 2). CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. 3).
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
